![]() | Home > General > Rear passenger door won't open ?!? |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Cheers again..
It may be worth trying to get someone to bounce the outside door handle at the same time….
This is a really common issue on all late Land Rovers…did one yesterday on daughters FL2..
Cheers FarmerChalk Will give that a try |
Had the same issue with daughters car but managed to open it by constantly unlocking it whilst pulling door handle… I think it’s where the motor just doesn’t have the strength to unlock the levers the last little bit…
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
Looks like I am going to need to do my Drivers side rear door lock... I did manage to find a way to open the door though.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
Do you have keyless entry and keyless/passive start?
Push button start and no proximity sensing for lock and unlock. |
Looks to be the right numbers, only now they seem to have been superseded to LR091360 as well. It does however mention a difference of either single or double locking but not sure what that difference means as thought all Sport's double locked.
Thanks Col.. Obviously the part isnt OEM but I am not overly concerned by that. |
OK.. I have an update to my "faulty" rear passenger door.
