Home > Advanced Factors > Servicing
Advanced Factors
Site Sponsor
Servicing
This is a post to help people find service items for their vehicles. Please let me know if I miss anything.
Service parts for Range Rover Sport L320 (2005 - 2013)
Service parts for Range Rover Sport L494 (2014- )
Original Equipment Filter Kits
L320 Range Rover Sport 2.7 TDV6 to VIN 6A999999(2005-2006)
L320 Range Rover Sport 2.7 TDV6 from VIN 7A000000 (2007-2013)
L320 Range Rover Sport 3.0 TDV6 (2005-2013)
L320 Range Rover Sport 3.6 TDV8 (2005-2013)
L320 Range Rover Sport 4.2 SC (2005-2013)
L320 Range Rover Sport 4.4 V8 (2005-2013)
L494 Range Rover Sport 3.0 TDV6 (2014-2022)
L494 Range Rover Sport 4.4 TDV8 (2014-2022)
L494 Range Rover Sport 5.0 Supercharged (2014-2022)
If you need a timing belt kit, you can find it here.
Range Rover Sport L320 (2005-2013) Timing Belt Kits
Range Rover Sport L494 (2014-2022) Timing Belt Kits
If you need parts to service your automatic transmission, you can find them here:
6 Speed Automatic Transmission
8 Speed Automatic Transmission Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Last edited by Advanced Factors on Fri Mar 25 2022 3:52pm. Edited 5 times in total
Post #622224 Fri Feb 25 2022 10:10am
Advanced Factors
Site Sponsor
Range Rover Sport L320 Service Parts (2005-2013)
Service parts for the Range Rover Sport 2.7 TDV6
Oils for the Range Rover Sport 2.7 TDV6
Engine Oil 5.54 Litres ADV901
Front Diff Oil 0.6 Litres ADV902
Rear Standard Diff Oil 1.1 Litres ADV902
Rear Electronic Locking Diff Oil (Look for a wire to a module) 1.5 Litres ADV909
Transfer Box Oil 1.5 Litres ADV903
Auto Transmission Oil 9.5 Litres Dry or 3.5-4.0 Litres Drain & Refill ADV905
Power Steering Fluid 0.9L ADV906
Coolant 9.4 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 2.7 TDV6
Filter Kits to VIN 6A999999 (up to 2006) KIT100 or OEM Filter Kit
Filter Kits from VIN 7A000001 (2007 onwards) KIT101 or OEM Filter Kit
Filters for the Range Rover Sport 2.7 TDV6
Oil Filter 1311289
Air Filter PHE000112
Fuel Filter to VIN 6A999999 (up to 2006) LR010075
Fuel Filter from VIN 7A000001 (2007 onwards) LR009705
Pollen Filter LR023977
Sump Bung 1013938
Glow Plug 1354289
Active Anti Roll Bar Filter RVJ100010 (only for vehicles with ACE)
Service parts for the Range Rover Sport 3.0 TDV6
Oils for the Range Rover Sport 3.0 TDV6
Engine Oil 5.9 Litres ADV914
Rear Electronic Locking Diff Oil (Look for a wire to a module) 1.8 Litres ADV909
Coolant 11.5 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 3.0 TDV6
Filter Kit KIT104 or OEM Filter Kit
Filters for the Range Rover Sport 3.0 TDV6
Oil Filter LR013148
Fuel Filter LR009705
Sump Bung 1013938
Glow Plug LR013275
Service parts for the Range Rover Sport 3.0 SDV6 2011-2012
Oils for the Range Rover Sport 3.0 SDV6 2011-2012
Auto Transmission Oil 9.5 Litres Dry or 3.5-4.0 Litres Drain & Refill ADV911
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 3.0 SDV6 2011-2012
Filter Kit KIT104
Filters for the Range Rover Sport 3.0 SDV6 2011-2012
Oil Filter LR013148
Sump Bung 1013938
Glow Plug LR013275
Service parts for the Range Rover Sport 3.6 TDV8
Oils for the Range Rover Sport 3.6 TDV8
Engine Oil 9.5 Litres ADV901
Coolant 13.1 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 3.6 TDV8
Filter Kit KIT106 or OEM Filter Kit
Filters for the Range Rover Sport 3.6 TDV8
Oil Filter LR002338
Sump Bung 1013938
Glow Plug 1354289
Service parts for the Range Rover Sport 4.2 SC
Oils for the Range Rover Sport 4.2 SC
Engine Oil 7.7 Litres ADV901
Coolant 12 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 4.2 SC
Filter Kit KIT107 or OEM Filter Kit
Filters for the Range Rover Sport 4.2 SC
Oil Filter LR031439
In Tank Fuel Filter WFL500010
Sump Bung 1013938
Spark Plug LR005253
Service parts for the Range Rover Sport 4.4 V8
Oils for the Range Rover Sport 4.4 V8
Coolant 9.3 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 4.4 V8
Filters for the Range Rover Sport 4.4 V8
Oil Filter LR031439
Sump Bung 1013938
Spark Plug LR005253
Service parts for the Range Rover Sport 5.0 V8 NA
Oils for the Range Rover Sport 5.0 V8 NA
Engine Oil 8.0 Litres ADV913
Coolant 10.8 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 5.0 V8 NA
Filter Kit KIT108
Filters for the Range Rover Sport 5.0 V8 NA
Oil Filter LR011279
Air Filter LR011593
Sump Bung 1013938
Spark Plug LR032080
Service parts for the Range Rover Sport 5.0 V8 Supercharged
Oils for the Range Rover Sport 5.0 V8 Supercharged
Coolant 14.1 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Filtes for the Range Rover Sport 5.0 V8 Supercharged
Oil Filter LR011279
Air Filter LR011593 (2 required)
Sump Bung 1013938
Spark Plug LR032080 (8 required)
Active Anti Roll Bar Filter RVJ100010 (only for vehicles with ACE) Paul Redding
+44 (0)23 8052 2776
Post #622225 Fri Feb 25 2022 10:10am
Advanced Factors
Site Sponsor
Range Rover Sport L494 Service Parts (2014 - )
Service parts for the Range Rover Sport 3.0 Supercharged
Oils for the Range Rover Sport 3.0 Supercharged
Engine Oil, Vehicles to February 2014 8.0 Litres ADV913
Engine Oil, Vehicles from March 2014 8.0 Litres ADV912
Front Diff Oil 0.54 Litres ADV902
Rear Standard Diff Oil 0.9 Litres ADV902
Rear Electronic Locking Diff Oil TVBB 1.3 Litres ADV909
Transfer Box Oil 1 Speed 0.75 Litres ADV910
Transfer Box Oil 2 Speed 1.5 Litres ADV903
Auto Transmission Oil 8.5 Litres ADV911
Power Steering Fluid & Active Roll Bar 0.9L ADV906
Coolant 8.9-10.7 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
Brake Fluid SVR Models LR067409
Filter Kits for the Range Rover Sport 3.0 Supercharged
Filter Kit KIT123
Filters for the Range Rover Sport 3.0 Supercharged
Oil Filter LR011279
Air Filter LR011593
Pollen Filter LR036369
Sump Bung 1013938
Spark Plug LR050998
Service Parts for the Range Rover Sport 3.0 SDV6 Hybrid
Oils for the Range Rover Sport 3.0 SDV6 Hybrid
Engine Oil 6.0 Litres ADV914
Rear Standard Diff Oil 0.9 Litres ADV931
Coolant 9.4-11.4 Litres up to 50% Antifreeze mix (To suit climate) ADV907
Brake Fluid ADV908
AddBlue 3.8 Min 18.0 Litres Max ADV924
Filter Kits for the Range Rover Sport 3.0 SDV6 Hybrid
Filter Kit KIT123
Filters for the Range Rover Sport 3.0 SDV6 Hybrid
Oil Filter LR011279
Air Filter LR011593
Fuel Filter LR041978
Sump Bung 1013938
Glow Plug LR128419
Service Parts for the Range Rover Sport 3.0 TDV6
Engine Oil 6 Litres ADV914
Rear Standard Diff Oil 0.90 Litres ADV902
Power Steering Fluid & Active Roll Bar ADV906
Brake Fluid ADV908
Filter Kit KIT125
Oil Filter LR013148
Air Filter LR011593
Sump Bung 1013938
Glow Plug LR013275
Service parts for the Range Rover Sport 4.4 TDV8
Oils for the Range Rover Sport 4.4 TDV8
Engine Oil 9.4 Litres ADV914
Auto Transmission Oil 8.5 litres ADV911
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 4.4 TDV8
Filter Kit KIT124
Filters for the Range Rover Sport 4.4 TDV8
Oil Filter LR022896
Air Filter LR011593
Fuel Filter LR072610
Sump Bung 1013938
Glow Plug LR013275
Service Parts for the Range Rover Sport 5.0 Supercharged
Oils for the Range Rover Sport 5.0 Supercharged
Power Steering Fluid & Active Roll Bar (CHF11s) 0.9L ADV906
Brake Fluid ADV908
Filter Kits for the Range Rover Sport 5.0 Supercharged
Filter Kit KIT123
Filters for the Range Rover Sport 5.0 Supercharged
Oil Filter LR011279
Air Filter LR011593
Sump Bung 1013938
Spark Plug LR032080 Paul Redding
+44 (0)23 8052 2776
Post #622226 Fri Feb 25 2022 10:10am
