Home > General > Supercharger pulley
I would take the 600Bhp claim with a pinch off salt unless I saw the results on a Dyno. My Transmission/Gearbox, Axles etc. on my 5.0L have lasted 5 years with no problem with a pulley upgrade and re-map. Have the readout here somewhere, if I remember right the torque went up to 750Nm on the Dyno and Bhp somewhere between 60-70Bhp.
Post #605599 Thu Oct 15 2020 8:26pm
mgrover
anyone know what a good replacement supercharge would be for the 4.2? Razz
Post #606096 Fri Oct 30 2020 7:29pm
Does anyone know if the supercharger has to come out to replace the pulley?
thanks --
Post #622106 Mon Feb 21 2022 8:43am
mgrover
hmmm, i did, but if you can get to all of the E torx bolts then nah.
because it is a Censored nightmare to remove the bolts behind the supercharger.
Post #622108 Mon Feb 21 2022 10:06am
thanks.
I see they have updated it to a two-piece pulley
Post #622110 Mon Feb 21 2022 10:26am
mgrover
actually which SC do you have? I was on about the 4.2 not the 5.0
Post #622112 Mon Feb 21 2022 11:27am
I've got the 5L, it's a 2015 L494, 375kW version. --
Post #622113 Mon Feb 21 2022 11:32am
The 4.2L has the Eaton M112 Supercharger the 5.0L has the Eaton Twin Votex TVS R1900. I don't recall Alive Tuning removing the S/C when they did the pulley on my 5.0L albeit a RRS1, they did the remap and pulley change while I waited, although to be fair I did not watch what they were doing and it was over 6 years ago now.
Post #622120 Mon Feb 21 2022 8:45pm
Gents, does anyone know where the filler plug is on the Eaton 1900 supercharger on the L494?
Can't find it at the front.
Thanks --
Post #622575 Tue Mar 08 2022 7:28am
That's because it's at the rear. Laughing
Post #622576 Tue Mar 08 2022 7:41am
Oh, FFS... 🤣 --
Post #622577 Tue Mar 08 2022 7:43am
Item No. 4
Post #622579 Tue Mar 08 2022 7:51am
Cheers Col, thanks.
I was wanting to change the oil while doing the pulley upgrade, but that's too much of a mission.
It'll have to wait until June, when the 7yr service is due, since it will be in the shop for a couple of days.
Had I know, I would have organised to have it done when they were replacing the crossover coolant pipe. --
Post #622580 Tue Mar 08 2022 7:54am
