![]() | Home > Faults & Fixes > L494 Warning Low Battery after x2 batteries replaced?! |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
It’s easy to check the battery with a multimeter you need to be getting 14.4volts with the engine running.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
I did what you did to no avail. I had that on & off for months even with Ctek connected. Dealer said nothing wrong but Auto electrician discovered a parasitic drain which took 3 or 4 days to find as he had to try something, let the system close down then try the next thing etc.
