![]() | Home > Faults & Fixes > 2007 RRS 2.7 none starter |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
What fault codes are showing if any? of course they want you to make the next decision then if it doesn't work you can't blame them as it was your fault not theirs because you told them to do it and you have to pay the bill. Find another "specialist" who knows what they are doing.
Matt_82 Member Since: 14 Feb 2022 Location: Blackpool Posts: 14 ![]() ![]() ![]() |
Cheers Col,
Is he referring to the Camshaft sensor or Crankshaft sensor reluctor ring, as that code is Camshaft Sensor related and the
Hi Col,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5008 ![]() ![]() ![]() |
There isn’t a cam reflector ring.
So what would the sensor pickup on then? as according to the workshop manual there is one although L/R do appear to refer to is a trigger wheel as well and is part of the exhaust camshaft gear which I assume is replaceable if required, and that fault code also specifically refers to camshaft sensor fault.
It’s interesting that the cam sensor is only used during start up.
Have to agree wouldn't be the first time L/R have made printing errors, there doesn't appear anything obvious on the gear for the sensor to pick up the signal from and no illustration in the manual as to what it actually picks up on either although it also says trigger wheel on the rear of the inlet camshaft which could be the three lobe metal part you mention. So is it on the actual camshaft or the gear? as L/R don't seem to be to sure. |
It on the exhaust side.
Hi all, the crank position sensor has been changed, witch didn’t resolve the issue |
Cam you mean |
Yeah, that picture is the TDV8 not Tdv6 I think the copy of the manual I was looking at appears to have a mixture of both TDV6 and TDV8 pages rolled into one. ![]() Cheers Col Last edited by Col on Tue Feb 15 2022 3:37pm. Edited 1 time in total |
First time round, cam sensor was changed. Car started.
Did you not say you refitted the old original cam sensor though?
