Home > Technical > 2016Range Rover Sport ACE Line replacement |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Front or rear pipes? |
Sun Feb 13 2022 4:32pm |
Skywagon Boy Member Since: 13 Feb 2022 Location: NB Posts: 4 |
They told me they are the hydraulic lines that run from front to the rear of the vehicle.
Sun Feb 13 2022 9:44pm |
it is both front and rear lines part numbers LRO85490, LRO85489, and valve LRO72419
Sun Feb 13 2022 9:58pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
I stand to be corrected here, but do they mean front and rear subframes ? as I though the L494 was mono frame style construction which means the actual body cannot be removed from the chassis/frame.
Col is correct, body is a monocoque with front and rear subframes
Sun Feb 13 2022 10:22pm |
How dies this pricing seem to you? Parts are two lines, and a new valve block |
Tue Feb 15 2022 12:54am |
Is the 9600 including parts or just labour, assuming that is Canadian dollars that's around £5500.00 UK pounds which if just for labour seems a awful lot of money to me, but Disco Mikey could probably answer that best.
Tue Feb 15 2022 2:35am |
