Home > Maintenance & Modifications > Fuel leak l320
Zoed
Fuel leak l320
Hi, I have just recently bought rrs l320 and noticed that it is leaking fuel. Can anyone suggest the best possible way to check where the leak is coming from.
Post #621837 Sun Feb 13 2022 4:05pm
Where are you seeing the leaking fuel? In the engine bay, underneath?
Did you buy it from a garage / car dealer? If so, take it back as they have to fix it. 2012 SDV6 - it's missing a couple of cylinders
Post #621839 Sun Feb 13 2022 5:21pm
Zoed
Fuel leak
It is leaking down the drivers side but at intermittent points. My husband looked under it and found this, see pictures
Post #621846 Sun Feb 13 2022 7:27pm
There is a fuel filter under the drivers seat. If that is where it’s leaking.
Remove the plastic tray. 10mm bolts.
And inspect
Ensure the drain on the bottom of the filter isn’t
Loose
Post #621849 Sun Feb 13 2022 9:53pm
Post #621859 Mon Feb 14 2022 9:07am
