Home > Technical > Trailer stability assist |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
If you're retro fitting the towing system, it will need to be "activated" in software too so that vehicle recognises it and performs correctly. The parking sensors should turn off when a trailer is connected to the electrical plug. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 12 2022 2:15pm |
houghta Member Since: 22 Oct 2021 Location: Cramlington Posts: 68 |
The tow bar was a retro fit but it’s LR designated electrics its showing the trailer icon but only when I indicate and I wasn’t sure if it should be on all the time when the engine is running, should they be or not?
Sat Feb 12 2022 2:26pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
The lamp just means the trailers indicators are functioning I expect.
Sat Feb 12 2022 2:42pm |
