Home > In Car Electronics > Software update |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1833 |
Call Land Rover Customer Services direct and ask them to enable Over the Air Updates ( OTA ) for your VIN?
Sat Feb 05 2022 4:21pm |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 248 |
I also believe you need a SIM installed. Recommend this 24 month data SIM -
Sat Feb 05 2022 8:29pm |
You need an active SIM or connect to a working WiFi. 2023 P440e SE Dynamic on order -cancelled
Sat Feb 05 2022 9:35pm |
brummytezza Member Since: 05 Feb 2022 Location: birmingham Posts: 9 |
Thanks all. I've contacted LR and waiting for a reply. I installed a SIM but no difference settings menu does not come up with an option to update. Will post if resolved. |
Mon Feb 07 2022 10:31am |
What version do you have now?
Mon Feb 07 2022 11:05am |
LR support have come back and said they cant help - take to retailer who want £186 just for a look! The RRS has been great for the last 4 years but every time I contact a retailer or LR support they are useless! |
Mon Feb 07 2022 2:18pm |
I have no idea how I find the software version number - I've looked thru all the settings menu and vehicle info menu. |
Mon Feb 07 2022 2:20pm |
It's in there somewhere in all settings, buti cannot remember exactly where on the old software.
Mon Feb 07 2022 3:10pm |
Thanks for all the advice. |
Mon Feb 07 2022 4:53pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 116 |
If I remember, I’ll come back to this thread and tell you how to find the software version when I get back to mine in a few days. What’s happening when you put the sim in? Do you get a 3G connection? As mentioned you should just be able to connect it to your home Wi-Fi if your signal is strong enough and update from there. Otherwise it sounds like a trip to the stealers is in order. |
Mon Feb 07 2022 11:14pm |
Thanks - yes both the wi-fi is working and the SIM is too - tested using traffic reports. If a trip to the stealer will sort it and give me an update and Apple car play I'd be happy (?) to do so. What's annoying is LR advice cannot tell me if this will work nor will the stealer commit to sorting it, but want a minimum of £186 for looking, I've given LR advice the VIN surely they should know? The problem as always is getting thru to somebody with technical knowledge rather than a millennial (at best) receptionist. |
Tue Feb 08 2022 10:39am |
Can you post a picture of your Home Screen? 2023 P440e SE Dynamic on order -cancelled
Tue Feb 08 2022 10:58am |
I’m almost 99% sure yours will support CarPlay if it is indeed a 2017 model. Mine is a 2017, but it was supported on some 2016 models and even some 65 plate ones have it. Ask your dealer how much for the update instead of the diagnostics.
Tue Feb 08 2022 12:19pm |
Attached are the screenshots of the system. The car was first registered in July 2017, it was the MD of the staelers car, which I bought at 6 months old. The reason I want an update is that when music plays from the phone after a short period it stops and nothing short of a restart will get it to play again. So Apple carplay will hopefully solve this? I generally don't use an in car SIM (I have put one in to test the system) but tether to the iPhones hotspot. This is a hit and miss affair and it takes some time for the RRS to see the phone (although it seems to see every other wifi signal in a 200m radius)
Tue Feb 08 2022 3:37pm |
