Home > My Range Rover Sport > TDV8 brought back from the dead …. 2 turbos later |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 |
Good job.
Fri Feb 04 2022 6:20am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
And, How many mlies on the clock? Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri Feb 04 2022 11:02am |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 |
Job done without removing body - quite straight forward but tight to say the least - exhaust needs to be removed along with rear gearbox crossmember- although you can pivot this down if you leave one bolt in . Then you need to work from inner arches and underneath - both upper front arms need to be removed too to help create space . Mine has just turned 142k and had full history with regular oil changes throughout.
Fri Feb 04 2022 7:46pm |
Fri Feb 04 2022 7:47pm |
Ended up fitting fully refurbished units worked out about £600 for the pair but you probably need to add another £100 for service kit and oil etc .. also you need to clean as much of everything as you can - I took about 3ltrs of oil out of the bottom hoses of the intercooler so you can imagine the cleaning required …… and it will still smoke like a trooper for about 30mins on the first run ! - true James Bond style ! |
Fri Feb 04 2022 7:53pm |
Fri Feb 04 2022 8:01pm |
Fri Feb 04 2022 8:02pm |
Fri Feb 04 2022 8:03pm |
Just got a full set of brakes to fit - front and rear. Clean and underseal the chassis and floor and fit some factory mud flaps as it looks as though it’s already had them so it will fill screw holes etc ….. oh and repair the satnav aerial as it’s current not reading a signal - all should be easier than the two turbos so all good ! |
Fri Feb 04 2022 8:07pm |
Nice job. A bit beyond my resources and limited facilities but interesting and certainly saved you a packet. Robin
Fri Feb 04 2022 8:23pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 215 |
Hi, great to hear another pair changed without removing the body. Just out of curiousity, did you replace the turbo oil feed pipes, is it possible to change them with the body on ? |
Mon Feb 13 2023 1:12pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
With a lift, taking the body off isn't the big issue that it's made out to be. It would certainly make all of that work removing the suspension, etc., irrelevant too so the time difference is probably miniscule. Of course, one needs a lift so...
Mon Feb 13 2023 1:43pm |
