Home > Maintenance & Modifications > Exhaust removal 4.2 S/C |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5008 |
I don't know the o.d of the s/c pipe or the tailpipe tips you are going to use, but L/R use this style clamp for fitting the exhaust tips on the exhaust when fitting the HST body kit which means no welding. they are available in three different diameters, 50, 55 & 60mm. Only a suggestion and certainly wouldn't pay L/R prices but probably available aftermarket.
Thu Jan 27 2022 10:27pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Not sure if it helps but here is a picture of my exhaust system from my 4.2SC when I had the middle resonator box removed and it was on the bench. Looks like they are welded on?
Fri Jan 28 2022 12:12pm |
Digger258 Member Since: 30 Sep 2021 Location: Scotland Posts: 8 |
Did notice this for sale on ebay which makes me think the rear section is detachable, but probably using a clamp is simpler as long as there is enough tube left before the silencer after grinding off the original tip.
Sun Feb 06 2022 9:45pm |
