Home > General > Range Rover Sport 2010 3.6 Ton of Module Faults
h5muu
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
Since i bought the vehicle i had 1 code which was adaptive cruise control not available which i was not fussed about.
Scanned the vehicle to finally fic any niggles as the centre dash clock was also not working and try to order the part etc, i was met with some new codes when scanned..
Car drives fine but feeling a touch heavy as the Dynamic Response Module seems to have stopped the arc system and is rolling a touch i can feel when driving / turning. So i have stopped driving the car.
SNAP ON SCANNER
-SPEED CONTROL MODULE
U0421-68 INVALID DATA RECIEVED FROM RIDE LEVEL CONTROL MODULE
-STEERING COLUMN MODULE
B1311-87 CLOCK MODULE
B1C99-15 RIGHT CORNER LAMP CIRCUIT
B1C98-15 LEFT CORNER LAMP CURCUIT
-BODY COLUMN MODULE
-DYNAMIC RESPONSE MODULE
C1B11-62 PRESSURE CONTROL VALVE
-INSTRUMENT PACK
B1A85-96 AMBIENT LIGHT SENSOR CURCUIT
-AUDIO CONTROL MODULE
U0159-00 LOST COMMUNICATION WITH PARKING ASSIST MODULE
-RIDE LEVEL CONTROL MODULE
C1A20-64 PRESSURE INCREASES TOO SLOW WHEN FILLING RESERVOIR
-TIRE PRESSURE MONITORING
Hopefully seems electrical or a loom/wire. any help is appriciated Thanks H
Post #621156 Fri Jan 21 2022 11:53am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Is your steering wheel straight when driving? have you had wheel alignments done? or need doing?
Post #621168 Fri Jan 21 2022 1:58pm
h5muu
Hi , thanks for the reply
No i would say it needs tracking for sure, the front lower wishbones & track rod ends need changing booked for wednesday .
Thanks H
Post #621169 Fri Jan 21 2022 2:01pm
Crraigymmmmm
Most of those issues seems related to badly aligned steering sensor.
Once reset, do they re appear after driving over a certain speed or on a long straight road?
Post #621170 Fri Jan 21 2022 2:14pm
h5muu
Hi, well no warnings show on the dash...
Its just becuase i scanned it i can see them... i would not have noticed otherwise apart from the arc system being down.
There is play in the steering and a knock.. What would you think the best steps are?
Clear codes and check right away? then clear and go for a drive?
Or just get the car aligned after the wishbones and track rod ends get done on weds?
Thanks H
Post #621172 Fri Jan 21 2022 2:53pm
Does the ride height rise OK when selected to off road height? The slow reservoir filling error suggests a tired compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #621174 Fri Jan 21 2022 3:25pm
h5muu
Hi
So the ride hight operates fine up and down and also looks level on the 4x4 screen, yes slow to raise but quick enough to settle on normal height. More concerned with the load of module faults.
Thanks H
Post #621175 Fri Jan 21 2022 3:34pm
