![]() | Home > General > DSC/ABS HELP |
TONY173 Member Since: 19 Jan 2022 Location: Tamworth Posts: 7 ![]() ![]() ![]() |
DSC/ABS ,
Any mis-matched tyre tread depths, I believe they may cause something like this if vastly different depths.
All tyres was replaced I’m told 4000 miles ago and all have good tread about the same, I did check Tyre pressures and they was low, I have topped up the pressures but made no difference |
If parked up for 12 months, might be worth just checking to see if you have a sticky brake caliper or guide pins. Could read this may help or give a clue.
Thank you |
Does the problem occur with DSC turned off? A way to check whether it is DSC causing it or something else. 07MY RRS TDV6
Don’t know I will try it |
No problem not there when dsc turned off, I have cleaned all sensors, calipers and greased guide pins, also checked Tyre pressures which was a bit low on the rear n/s. Still got problem but not as bad |
Have you had the codes read to see if there are any showing? might give a clue.
