![]() | Home > Technical > heated screen |
Check fuses 15 & 18 in engine bay fuse box. 15 is R/H section 18 L/H section.
connections are inside the car, behind the A pillar. (one torx bolt behind the Airbag screw cap)
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
thanks col I thought there might be two fuses |
thanks Andy got a mate who is a auto electrician will get him to check with me |
Andy is the A pillar passenger side or the drivers side |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
both sides, mine doesnt work either..lol |
The side that doesn;t work |
thanks for that I wasn't aware it had a wire on either side of the pillar I thought it was connected at the bottom |
