![]() | Home > Maintenance & Modifications > I need help: LED bar Fitted with HighBeams |
Whoosh Member Since: 05 Nov 2021 Location: Scotland Posts: 35 ![]() ![]() |
What light bar did you buy and where did you get it .
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
Simple process of rerouting the positive trigger for your lights relay from the switch to the positive feed on one headlamp high beam. Place a Diode on the feed from the headlight high beam to prevent any backfeed into the central junction box which may trigger an error on your highbeam circuit.
Abandito Member Since: 13 Feb 2017 Location: Preston Posts: 24 ![]() ![]() ![]() |
Easiest way would be to connect to back of one of your headlights and connect to high beam wire, think it’s 11 or 12 off memory, but easy enough to test with a meter.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Main Beam supply looks like Pin 10 Blue wire with Black tracer O/S headlight. N/S would be same Pin No. but Blue wire with Grey tracer.
deceunincke Member Since: 04 Jan 2022 Location: Roeselare Posts: 14 ![]() ![]() ![]() |
Hi
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Missing picture |
Very subtle |
Thanks!
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 247 ![]() ![]() ![]() |
That looks great i want to put one there aswell been looking at the black osram ones, Which light bar did you get? |
I got the osram vx500 ledbar.
Thats the exact one i have lined up, it looks well made and i like osram. I have them for my daytime running lights very good quality they’re. I wanted to put one on the roof aswell but maybe this one in front bumper with be enough light?
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Is there not a cooler behind there? Joined the X5 45e club
Dave, Do you think the light bar would cause an issue to the cooler? I didnt think it would restrict any air flow tbh theres alot of space at both sides of the light? |
