Home > Faults & Fixes > rrs steering gone heavy |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 |
Hi check the link shaft from the steering column to the rack there is a joint if I’m correct that starts to seize on small Uv type joint.Normally best if it is that is to get new one fitted think if Independent LR Garage price fitted about £250 |
Wed Jan 05 2022 10:05am |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 68 |
is it heavy or "lumpy"?
Wed Jan 05 2022 11:47am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 |
I had the same problem on my 2005 a couple of years ago. Took it to my mechanic who lubed all the UJs. No problem since. Barrie.
Wed Jan 05 2022 12:02pm |
bricky0 Member Since: 05 Jan 2022 Location: bolton Posts: 3 |
many thanks guys lube up lower uj problem for now fixed
Fri Jan 07 2022 4:57am |
Good news! Barrie.
Fri Jan 07 2022 7:11pm |
