Home > Tips & Tricks > Bonnet not latching
stevoc
Scotland
Bonnet not latching
Hi guys. So was checking water and oil levels,as you do, and afterwards I couldn’t get the bonnet closed again!!
So cleaned out the latches as described on here by another kind member but to no avail. Was slamming it and even trying to soft close it by standing on a small chair and pressing down firmly on the bonnet at the point above the latches. Much to my neighbours mirth I may add. So after much pelters from her indoors I took it down to my local mech,driving slowly I may add 😬. Couple of minutes later problem solved. So standing at the front of car arm yourself with a flat head screwdriver.
On the left hand side catch only insert the flathead just down below the front of the cam and from there you can pop the cable stopper just forward enough for the mechanisms to function the way they should. Bonnet closed and no more alarm going off when locking the vehicle. 👍 so no doubt I will need a new cable fitted eventually but hopefully this quick tip will save some members much angst and strife lol
Post #607350 Wed Dec 09 2020 11:59am
karlos01
hi i know this post is old but any chance if you still have the RR you could post a picture of where you placed the screwdriver as I've got same issue with my 05 RRS and short of buying new latch if it just simple fix like this would be good
thanks
Post #620598 Thu Jan 06 2022 7:32am
karlos01
thanks
Post #620599 Thu Jan 06 2022 7:32am
Mike London
Sometimes the bonnet release latch stays in the midway position after opening. This may prevent the bonnet from locking again afterwards so fully return the plastic puller in the passenger footwell to its fully closed position first and then try to close the bonnet/hood again 2014 RRS AB Santorini Black
Post #646082 Sat Jan 04 2025 4:33pm
