![]() | Home > General (L494) > HELP- tried to Retrofit a Heated steering wheel |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
You probably have to activate it in the CCF files.
nycman Member Since: 20 Dec 2021 Location: NY Posts: 3 ![]() ![]() |
This is my first RR, but pretty handy with cars and trucks. Pardon my ignorance, but what is a CCF File and how would I go about activating it.
Car Configuration Files, however you would need a diagnostic tool to access it and activate or change any settings. A L/R dealer should also be able to do it for you, or a Independent L/R specialist workshop if you have them in the States.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1853 ![]() ![]() |
No mention of changing any CCf entries on the link I posted for you on the USA site.
The controls are different and the airbag connections are different from a 2016 to 2019. For example, there is only one air bag wire instead of 2 that was used in a 2016. I have a 2019 and went by the only info I could find online that was for a 2016. The phots show the controls I have. Hopefully will find the the answer to this.
