Home > General (L494) > Anti Roll Bar arm replacement |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
The ram is built into the ARB. If the bushes are worn, just the bushes should be replaced, not the whole ARB and no fluid is required to be drained, it's just the same as fitting bushes on a standard ARB. Kev
Sat Dec 25 2021 8:37pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
As Kev says, if the bar isn't leaking just have the bushes replaced. They may try to tell you that the bar is worn, but try replacing them with polybushes as they will last a lot longer than gen LR rubber ones. The access is very tight and there is a special tool to undo the bolts. I'm assuming you are using a independent LR specialist garage. |
Sun Dec 26 2021 9:30am |
