Home > Technical > What connectors are these to?
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Not sure if I titled this to post so apologies if you have already seen this.
Can anyone tell me what these connectors should be connected to., found them cut off while removing headlamps.One each side , extra one for clarification.
Post #620260 Fri Dec 24 2021 3:19pm
For tyre pressure monitoring. Where fitted
Not cut off. Just sealing bungs
Post #620265 Fri Dec 24 2021 7:19pm
As said, TPMS connectors. Ignore them and leave them alone. Thumbs Up
The reason they're there is, because in the original RRS, the entire loom was fitted - that's every wire for every device. So you end up with a lot of stray connectors around the place. 2012 SDV6 - it's missing a couple of cylinders
Post #620268 Fri Dec 24 2021 11:07pm
alfapat
Thats great , just looking around this vehicle as I repair this and that , it looked like they were abandoned, all good Thank you guys .
Post #620272 Sat Dec 25 2021 12:38pm
