Home > Maintenance & Modifications > Bank B sequencer chain snapped
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Andy K wrote:
You really need the cam retainers
But i don’t know what you have to loose, reuseing old ones.
Injectors aren’t coded
Jaguar 2.7 heads are the same
Hi mate do you think i could reuse the cam retainers off my existing head? My thought process is, I can prob get another full head for 150. The time wasted if mine dont work would outstrip that amount anyway?
Also heres a strange one. I refitted the auxiliary belt and gave her a good rev up and seem to now have full power and idles ok?
I do hower have a bad tapping sound but wondering if could just be a tappet thats drained and possibly needs a good run?
Post #620150 Mon Dec 20 2021 8:06pm
If it’s taxed etc. Then give it a run and see.
When you have it apart, you could swap the cams and cam caps over, rotate by hand and ensure they turn freely.
Remove caps and ensure there are no score marks
If in doubt , you have plenty of time to order a Head
But yes, 150 is a small amount when you consider the cost of parts you can’t use twice.
Headbolts, head gasket and your time
Post #620154 Mon Dec 20 2021 9:26pm
looneyfitter
Thanks Andy. Will go for that. Cheers mate
Post #620164 Mon Dec 20 2021 10:53pm
