![]() | Home > Technical > Loose battery connections |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
Folks
Peterh Member Since: 07 Jul 2020 Location: West kirby Posts: 29 ![]() ![]() |
Wrap the post in tin foil to increase the diameter or file the clamp so as to allow it to close more . |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
Had the same issue, used a thin strip of metal to go half way round the battery terminal, opened the clamp up as suggested, and tapped it back over the terminal.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I'm with Andy,,, i've had the same trouble, if the terminal is not pushed as far down as possible it will not tighten around the battery post. 2010 RRS, TDV8
I’ve ‘tapped it’ |
