![]() | Home > Technical > My RRS TDV6 WON'T MOVE....!!!! HELP...!!!! |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
sounds like a drive shaft or prop' shaft, easy enough to check, make sure you have some axel stands to hold the car up.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
These posts crop up every now and again on here. I have heard of outcomes range from catastrophic engine failure to a very low battery, or even a fuse blown.
sounds like the gearbox to me.
Alfafox Member Since: 16 Dec 2021 Location: Beziers Posts: 4 ![]() ![]() |
Thanks All.....!!!
And the batterie is ok: 12,7
Maybe read her fault codes
