Home > For Sale & Wanted > [Wanted] 2010 brembo front and rear calipers wanted |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5008 |
L/R have never fitted Brembo Calipers to the rear, even on the SVR's they are TRW on the rear, you could try one of the Big Brake upgrades from the likes of JE Engineering but they are not cheap.
Mon Sep 20 2021 8:48pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 226 |
That might explain Col why powerful uk just have the front kit on there website, I thought i saw some sort of brembo callipers on the rear somewhere of a l320 i will try and find a picture but might be the wrong model now you day that. Hoping to find someone scrapping one so i can swap everything over thats needed and ideally paint the calliper black or drop on one black but then im probably pushing my luck. Seen a few with 4 pot and some 6 pot am i right thinking its the 6 pot ones? |
Mon Sep 20 2021 9:27pm |
My old TDV8 had the 4pot brembo's but with Range Rover decal branding, my 5.0L S/C has 6pot brembo's, if you run 19" wheels by any chance you are very limited with genuine rim's that fit over the 6pot's.
Mon Sep 20 2021 9:41pm |
Well I have 21 inch wheels so have enough room, the powerful uk kit might be the best and easiest option with it having the bigger guards and all fittings with them, oh and its 6 pot. I would prefer for some feedback from others that have gone with them before i throw £995 away. Surely a few of this forum have fitted them? |
Mon Sep 20 2021 9:50pm |
Managed to get myself a set of front brembo callipers of ebay but theres no clips that hold the pads in or the studs, Do they come with new pads as a set or does anyone know where i can set some from?
Sat Dec 11 2021 11:30pm |
I think you might need this fitting kit.
Sun Dec 12 2021 1:04am |
Hi Col apparently brembo on tdv8 was an optional extra i was told but you would think the weight of the tdv8 then they would mean they would come as standard. Do you think these 4 pot brembos will be much better braking then the standard brakes i have? Or would i need the 6 pot brembos to see a difference because if theres not a noticeable difference with just 4 pot ones i may sell them on and try and source the bigger 6 pots. |
Sun Dec 12 2021 9:16am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Sorry to Hijack here but it might also help you. Will these Brembo calipers mount on the original 360mm discs and hoses etc or is there a carrier / pipe mod needed? |
Mon Dec 13 2021 10:15am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
6 pot Brembos require 380mm discs, however the backplates/splash guards on my 2010 did not need changing.
Mon Dec 13 2021 12:11pm |
Dave did you go from 4 pot brembos? Im trying to work out if its worth fitting these 4 pot brembos or selling them and sourcing some 6 pots. Not sure if theres a big difference in stopping power, I currently have the standard callipers on my tdv8 cant believe it came with them the brakes are terrible. |
Mon Dec 13 2021 12:27pm |
Not sure what you have fitted already, but the 6 pot conversion is, at least for me, a must if you like spirited driving.
Mon Dec 13 2021 12:46pm |
I have a tdv8 2010 with standard rubbish callipers, just bought 4 pot brembos i intend to have fitted but Im trying to find out if i will see much difference or should i sell these and go for the 6 pot brembos? I know bigger is always better 😃 but is it worth the extra cost or do people with 4 pot brembos think they have enough stopping power because the standard ones ate not fit for purpose on the tdv8 imo. |
Mon Dec 13 2021 8:29pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
Not sure if you’ve gotten an answer, but I’m hoping to put some 4 pot Brembos on my 2011 TDV6 within the next few weeks. I know it’s not the TDV8, but it’s only a 25HP difference and not too far off with the weight. I also find the brakes to be a little lacking so hoping this will help a bit. |
Sat Jan 29 2022 2:55pm |
I missed a couple of questions last time round, so hopefully this might help.
Sat Jan 29 2022 3:36pm |
