![]() | Home > Maintenance & Modifications > Advice - Indie to change Air Suspension Struts RRS MY2012 |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Hi, with all respect, if you have every worked on a car before this is a very straightforward DIY job with basic tools.
pprod Member Since: 30 Nov 2021 Location: London Posts: 4 ![]() ![]() ![]() |
Hi Crraigymmmmm
Fair enough, just didnt want you to be put off doing it yourself. I was a little intimidated by the the whole RR thing but they are actually quite easy to work on - sometimes. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
From what I can see on here, most reputable independent garages won't fit customer supplied parts because; a) insurance issues if the part you supplied fails and b) they make a profit on parts they supply which tops up their labour rates.
Try Dartford Transmissions and Autocare but Martin may not want to fit customer supplied parts Visitor from fullfatrr.com
