Home > In Car Electronics > Not reading Sim card |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1829 |
If you are sure you are putting it in the correct way then a Card Reader problem.
Sun Nov 21 2021 3:59pm |
Mgs1000 Member Since: 21 Nov 2021 Location: Oxford Posts: 34 |
I’m sure I’m putting it in correctly, it’s a fiddle but it does click into place.
Sun Nov 21 2021 4:05pm |
It does click into place, not sure about cost of replacement as the older posts are regarding cars that were still in warranty. 2023 P440e SE Dynamic on order -cancelled
Sun Nov 21 2021 4:22pm |
AlM Member Since: 08 Feb 2021 Location: Melbourne Posts: 51 |
I had a similar problem with a MY21.5 RRS. The dealer replaced the SIM card reader. Evidently a not unknown problem- they had plenty of spares! All good now. MY21.5 HSE 221KW D16
Mon Nov 22 2021 8:18am |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 116 |
I'm on my third card reader so far and expect another at some point. All covered on warranty. |
Mon Nov 22 2021 12:21pm |
Wilco Member Since: 20 Mar 2021 Location: Somewhere in Time Posts: 31 |
Had a similar problem, dealer found slot was full of fluff/dust, so card was not engaging fully in slot.
Mon Nov 22 2021 1:25pm |
Discovered a new quirk… Apple CarPlay and the SIM don’t play nice together. If I plug up the iPhone before the SIM has been read by the Infotainment system, then the SIM will not be recognised, and vice versa.
Sat Dec 04 2021 9:51am |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 |
Do you use any data sim ? RRS HSE DYNAMIC 2015 ODESSEY RED |
Sat Dec 04 2021 3:11pm |
I have always used the Three SIM. 2023 P440e SE Dynamic on order -cancelled
Sat Dec 04 2021 3:40pm |
On average how much data per month ? RRS HSE DYNAMIC 2015 ODESSEY RED |
Sat Dec 04 2021 8:35pm |
I use EE, but I reckon the maximum it uses is 100mb unless it needs an update. |
Sat Dec 04 2021 8:48pm |
Thank you will look for a deal on 2gb to be on safe side RRS HSE DYNAMIC 2015 ODESSEY RED |
Sat Dec 04 2021 8:56pm |
