![]() | Home > Maintenance & Modifications > Bank B sequencer chain snapped |
I guess you can live with a missing link.
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Hi Andy, managed to get her all back up and running today she started within 20 seconds, but is running rough. Almost as if only running on 5 cylinders. Ive pulled injector connector off bank B one at a time and no noticable difference to engine note/tone.
You aren’t meant to pull inj. Connectors off these while running. They can jam open.
Ah ok thanks mate. I didnt know that.
Gp access is poor passenger side.
Hi Andy, not really had any time to look at this. But just before i do. Could the alternator not working possibly have anything to do with mis fire? Lack power? Ie the ecu is limiting it? Has a fully charged battery and starts on the nose.
Given what’s happened, it’s likely a bent valve
Thanks Andy. Really didnt want to hear that mate. Is the exhaust manifold as difficult to remove as i think? 😫 |
The exhaust isn’t too much of an issue.
Thanks andy will comp test and update. If comp is low, is it new head time or replace valves?
Get a used head off eBay. |
Hi mate, purchaced a head but didnt realise it doesnt come with cams or cam retainers. Can i just swap them over from my head?
You really need the cam retainers
Thanks Andy. Looks like i need to take the plunge. |
