Home > General > Locking wheel nut |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The first thing I did when I got mine was to bin the locking nuts, as I suspect you're doing. I would try ringing a few local tyre fitters, it may be they have experienced this and may have a way to get them off.
Fri Dec 03 2021 11:00am |
Fri Dec 03 2021 7:30pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
I managed to lose mine when I forgot to take it off the wheel one day before I drove off.
Mon Dec 06 2021 4:20pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
There are twenty different keys as they don't use I,O,Z and a couple of others if i remember right, the other thing is which doesn't help in the slightest unless you can get one nut off in some way, is the letter is actually stamped on the locking nut itself, unfortunately you have to remove the nut to read it as its stamped on the flat washer part that sits against the wheel rim
Tue Dec 07 2021 11:20am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
When you can, remove them all, throw in bin and fit normal nuts all round.
Tue Dec 07 2021 3:00pm |
