![]() | Home > Technical > track rod ends |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 951 ![]() ![]() ![]() |
Look on advance factors website, they will have what you need along with part numbers if you want to look elsewhere. 2010 RRS, TDV8
I have a pair of genuine one's here bought for a 2012/2013 car and the L/R part number is LR010676 although that may have been superseded by now, they do not appear to be handed so same one for both sides.
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Thanks Guys, Im a gen parts only but not at RR prices |
I think you must have been looking at Lemforder parts which I think are the original brand. Advance factors stock Lemforder,, but I would seriously think about Meyle parts,,, heavy duty and as good if not better than a lot of the original parts,,,,,, and half the price,, and German if your that way inclined. 2010 RRS, TDV8
The genuine one's I have here have made in the UK on the packaging, the actual end has Land Rover stamped on it as well as the Lemforder logo although not the name so assume the o.e parts are Lemforder who are actually owned by the ZF Group so anybody guess where the parts are actually made.
Thanks guys. Is there also 2 different thread sizes for the swivel joint too? Or are they all the same? |
https://www.advancedfactors.co.uk/steering-rack--ends-293-c.asp
The original RRS had a smaller track rod end which was later changed to a larger one. That's why there is more than one size available. 2012 SDV6 - it's missing a couple of cylinders
