![]() | Home > Technical > Rear Light Cluster Replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
On a 2010 car they should be a straight swap plug and play, it used to take "thieving scroats" about 30 seconds to remove a pair without even opening the tailgate, so give yourself 5 mins and a cup of tea would be about right
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I replaced my old 2008 ones with the new LED ones from Powerful UK (https://www.powerfuluk.com/vehicles/range-rover-evoque-sport/sport-2010/lamps-light-upgrades/range-rover-sport-2012-spec-rear-led-lights-no-resistors.html). I got them with the resistor fitted and then its just a straight swap. As yours is 2010 it may be worth checking with Powerful as to which you need. And whilst you are at it get some security screws to reduce the chance of your new lights getting nicked (search on this forum for more details if interested) Robin
Darren Anthony Member Since: 08 Mar 2019 Location: Birmingham Posts: 30 ![]() ![]() ![]() |
If you get the ones from PowefulUK then they supply some hex screws as well as normal ones to help to stop them being stolen.
