Home > Technical > Heated seat hot spot
Weston18
After getting a burning sensation after a few minutes of the heated seats being on I thought I’d do some investigation. Using a thermal camera I took some pictures of the seats.
Interesting to see exactly where the element runs.
The drivers seat has a hot spot seen in the photos that reached nearly 90 degrees.
Post #619478 Thu Nov 25 2021 7:55am
They do eventually fail by burning out. I had similar on my old TDV8. Simple enough job to fit a new heating element pad.
If you do a search on the forum there are a number of threads about it. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #619514 Thu Nov 25 2021 9:04pm
Weston18
I will add it to the list of jobs thats slowly growing. Does it take long to strip the base down to replace? Not sure if its worth the hassle or keep an eye out for a replacement seat.
Post #619517 Thu Nov 25 2021 11:04pm
Good opportunity to renew the foam seat pad at the same time as they do tend to collapse over time and age with sliding in and out.
Post #619518 Thu Nov 25 2021 11:33pm
See for yourself:
https://www.rrsport.co.uk/forum/topic43630...se+removal
I just bought the bits and had my indie do the work. Didn't cost much although I can't remember the details as it was a while ago now. 2012 SDV6 - it's missing a couple of cylinders
Post #619519 Thu Nov 25 2021 11:34pm
Weston18
Spot on, thanks for finding that. I’ll get it done. Rear hub top bush today…….slowly working through the list.
Post #619526 Fri Nov 26 2021 12:12pm
