![]() | Home > My Range Rover Sport > New RR Sport Owner |
nazim.yunas@btinternet.com Member Since: 08 Nov 2021 Location: Stoke Poges, Buckinghamshire Posts: 12 ![]() ![]() ![]() |
Hmm tried to upload some pictures but its not being visible for some reason? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
![]() 2008 TDV8 - it was a labour of love and is much missed |
Thanks RRS TDV8! |
For the ride - yes, the 22 inch rims won't be helping. The suspension was designed for 19 and 20 inch wheels and the associated sidewall depth but also the suspension might be a bit tired now with 125k on the clock. It's worth noting that air suspension can be a bit crashy on certain surfaces although I think it's still better than coils would be. A swap to 20 inch rims and 275/45 tyres could help here - that would be a slightly deeper sidewall than the standard 275/40 tyres.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Nice looking car love the colour, but I don't think you will find that it is a HST, as it appears to have Autobiography front and rear bumpers fitted not HST one's, also look's like someone has fitted a one piece tailgate as well from a later car or the wrong spoiler.
Thanks RRS TDV8 I had a feeling the 22" wheels would be the main culprit and thanks for the advice on the tires that makes perfect sense! |
Hi Col, Thanks for the input on the HPI report it definitely comes up with HST but I forgot to mention this is a previous cat D car so I am guessing when this was involved in an accident the correct parts have not been fitted or were changed by the owner at the time? Naz |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
Looks like they did a lot of work and effort when they repaired it as well as expense, as they obviously changed the front wings, headlights etc. to match the later A/B bumper as well as updated rear lights. Is it possible it was stolen and partly stripped, not accident damaged which made it a cat D. Not sure about the chrome bling though. |
Hiya and welcome. RRSTDV8 has covered it above. I run 20’s during the summer and put 19’s with winters on over the (err) winter. I think the ride is very comfortable on 20’s but it’s noticeably smoother when on 19’s. However you’ll loose the look of those massive 22’s , so you takes your choice. Contact Bodsy on here for a gearbox flush, he’ll also do your diffs and transfer box if you want. Couldn’t tell you an indie around your way though, so think about putting up a separate post. 2006 2.7 TDV6 HSE in Cairns Blue. |
Rovertune in Reading would be worth a call if you're looking for an indie. They've been recommended by others on here over the years although I have no experience of them. 2012 SDV6 - it's missing a couple of cylinders
It’s a good point not sure as the Cat D was recorded in 2011, yes the chrome bling is a little too much for me but this was all done by the last owner |
Thanks for advice and will reach out to bodsy very soon ![]() |
