Home > Australia & New Zealand > LED Daytime running lights
ibmfella
Australia 2011 Range Rover Sport 3.0 TDV6 S Fuji White
Can anyone tell me how to get the LED's indicated below to illuminate as DRL's?
Post #618783 Fri Nov 05 2021 9:41pm
scarey
they need to be activated in the car configuration file [ccf] ...use a capable diagnostic tool like the GAP iidtool...
but i wouldnt bother as these lights are not very bright....i would convert the fogs into drl's or stick some aftermarket lights on..
Post #618792 Sat Nov 06 2021 7:28am
ibmfella
Thanks very much for that scarey. I think you've saved me a LOT of head scratching! Thumbs Up
Post #618793 Sat Nov 06 2021 7:43am
You can't activate them as purely DRL's on there own in the CCF files, it has to be in conjunction with dipped headlights and rear lights. The only other way is to modify the wiring in some way I believe.
This is a extract from a reply I added to a Post about 6 years ago. "Just as Reference have gone into the CCF files and there are three options listed for DRL's on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over �400.00
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights.
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
I hope that all makes some kind of sense."
Post #618948 Tue Nov 09 2021 8:03am
Abandito
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Rimini Red
There’s been several posts where people mod the wiring in the fuse box to put the DRL lights on auto
Link https://www.rrsport.co.uk/forum/topic55116.html
Post #619154 Sat Nov 13 2021 10:15pm
