Home > General (L494) > Heated seats
HaggisMan
Heated seats
Is it just me or are the heated front seats in a RRS barely worth the name? Even at their hottest setting they only get tepid whereas on various BMWs and Audis I’ve had they almost set your trousers on fire. At setting 1 or 2 it’s barely noticeable at all. There’s also almost no detectable heat on the backrest. I don’t sit in the back so don’t know what they’re like there, but hopefully the heated steering wheel on my next one will be more impressive.
Post #618715 Thu Nov 04 2021 10:39am
jd2uk
I'd say there's something wrong with your heated seats - my MY2018 seats get uncomfortably warm on the highest setting.
Post #618720 Thu Nov 04 2021 12:51pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
the seats get very warm, you only need them on for around 2 minutes, before it becomes uncomfortable.
your heating pads probably need replacing.
Post #618722 Thu Nov 04 2021 1:29pm
TheGoodWillOut
Mine work really well, do take a few mins to warm up though and then have to turn down.
Post #618724 Thu Nov 04 2021 1:45pm
HaggisMan
Mmm, interesting. I’ve had the car since new 3 years ago (MY19) and the seat heating has never been impressive since the start - I’ve certainly never had to turn them down cos they’re getting too hot, that’s for sure!!
However the lease expires in a couple of months and it’ll be away, so I’ll live with it a bit longer and hope the replacement is better.
Post #618728 Thu Nov 04 2021 3:50pm
RRT
Having come from a MY13 RR Evoque, the seats do not warm up anywhere near as quickly, but they do get hot eventually. I do miss the near instant heat. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #618729 Thu Nov 04 2021 4:29pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
My 2012 RRS seats used to heat up much quicker than my 2015 RRS. I have put it down to the newer car having heated and cooled seats so may have less heating elements in the pads due to having cooling bits too.
Post #618748 Thu Nov 04 2021 9:26pm
IanV8
Scotland
If you have heated/cooled seats they do not have heating elements, they use a Peltier device which heats or cools depending on which way round it is connected.
They are slower to heat up but my 2018 gets very hot on 3.
Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser.
Post #618752 Fri Nov 05 2021 8:28am
Grimble
I have never used my heated seats, but would not want to be without the heated steering wheel. If both were options I personally would go for the heated wheel every time.
I had a Volvo in the early 90's which was my first car with heated seats. I switched on the passenger side with my father in law onboard. After a few minutes he thought he had wet himself. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #618757 Fri Nov 05 2021 10:32am
Johnrrs
Ian
I didn’t know that. Mine get very hot too but does take a bit longer than normal heated seats.
Post #618771 Fri Nov 05 2021 6:24pm
Martyn
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Mine take a little longer than my Mercedes did but after 10 minutes both back and seat are hot, and need turning down
Post #618858 Mon Nov 08 2021 7:49am
gtr_skyline
my MY16 gets way too hot on the lowest setting beofre it stabilises to a comfortable temp MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian
Post #618969 Tue Nov 09 2021 4:19pm
Kevin-t
To be totally honest, my old disco 3 seats warmed up a lot quicker. However the heated steering wheel is new to me and is almost instant Thumbs Up
Post #618970 Tue Nov 09 2021 4:27pm
