Home > Faults & Fixes > 2015 RRS heated seats.
LesW
France 2013 Range Rover Sport SDV6 HSE Santorini Black
Hi folks.
I seem to have a problem with our recently acquired RRS.
The front left seat plus both rear seats heating are not working. The front right works perfectly.
I've checked the settings on the centre screen and all looks OK.
I will start checking fuses, but, if any members have any help please let me know.
I don't fancy going back to the place I bought it from as it's 200 miles away.
Cheers. Les. 2015 RRS HSE Dynamic 3.0 SDV6
2015 Aston Martin Vanquish
2010 Jaguar XFR Le Mans
2001 Volvo V70
Post #618663 Wed Nov 03 2021 8:02am
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Normally the heating pad has a break in the wire, if there is current to the terminal, you have a faulty pad.
Post #618689 Wed Nov 03 2021 1:04pm
LesW
Thanks Kas.
I imagine that would necessitate a new pad, or 3 as it happens.
2001 Volvo V70
Post #618693 Wed Nov 03 2021 1:11pm
LesW
A bit of an update.
One of the fuses, the one for the rear seats, had blown. I changed it and now have the righthand rear seat working, the front and rear left still don't work.
So, I'm guessing it will have to go to an Indy in Cheshire when we can get over there for a good check out.
At least my wife and daughter can sit on the warm side. 2015 RRS HSE Dynamic 3.0 SDV6
2001 Volvo V70
Post #618714 Thu Nov 04 2021 10:08am
kas982
Do you have current ( 12v ) to the element?
Post #618721 Thu Nov 04 2021 1:25pm
LesW
Hi Kas.
I haven't checked as yet. The car is new to me and I'm not too savvy on it's layout so far. I've got the workshop manual but they are definitely not as easy to follow as they were when I was a youngster.
I presume it's a case of unbolting the seats to get to the connectors for a look see.
If you know of a short cut, I'm all ears!
If it's the pads, are they easy or difficult to swap. Mine also has the seat back heaters.
2001 Volvo V70
Post #618723 Thu Nov 04 2021 1:41pm
LesW
Just another update. The fuse for the rear has blown again.
I'm going to call it quits and get a sparky to check it out. 2015 RRS HSE Dynamic 3.0 SDV6
2001 Volvo V70
Post #618727 Thu Nov 04 2021 2:54pm
