Home > General (L494) > Timing chain
Martyn
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Timing chain
Hi Guys I'm thinking of returning to a RRS but this time I am looking at a 2015 TDV8 was wondering if the timing chain is a life component or needs changing like the TDV6 .......Also I hear these engines are more reliable.....Any help will be appreciated guys before I part with my hard earned
Post #616632 Mon Aug 16 2021 4:42pm
OvalAutos
Timing chains are not a service item, they're for life Whistle
Issues with the timing system are usually related to poor servicing or poor quality oil. Over time the plastic guides can become brittle and break apart. When this happens, the chains will become slack and you'll notice it by the change in engine noise.
The system uses 2 chains. One is a double chain and the other is a single chain. I've only ever seen a single chain break. Joe
Post #616658 Wed Aug 18 2021 6:38am
Martyn
Thanks for your reply mate
Post #616661 Wed Aug 18 2021 7:44am
HappyHammer
United Kingdom 2011 Range Rover Sport Supercharged Sumatra Black
Hi guys,
RRS 2011 SS…
Looks like the timing chains may need to be replaced. She has 65k on the clock.
Any idea what sort of cost i should expect from an Indy?
Thanks,
Paul. RRS 2011. 5L, S/c in Sumatra Black. She's lurvely.
Post #618565 Sun Oct 31 2021 10:25am
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Depends if you want oem parts.... i'd budget for around £1500 -£2000. They also might find other issues that could push the bill up.
Post #618583 Mon Nov 01 2021 12:16am
HappyHammer
Thanks alot. RRS 2011. 5L, S/c in Sumatra Black. She's lurvely.
Post #618626 Mon Nov 01 2021 7:46pm
