Kot
![](templates/vbnew/images/spacer.gif)
This is 2016 handbook maybe its the same for a 2015?
https://www.ownerinfo.landrover.com/docume...c/G1803703
Mon Nov 01 2021 8:44am |
thdxb08
On a 2015 the access height can be set to auto see RR Sport manual https://www.ownerinfo.landrover.com/docume...c/G1823191
AUTO ACCESS HEIGHT
NOTES
Auto access height operation is more efficient and smooth with the Electric Parking Brake (EPB) applied and the brake pedal completely released.
Auto access height automatically lowers the electronic air suspension to the access height setting, when the vehicle is parked. See ACCESS HEIGHT.
Auto access height is enabled or disabled, via the Vehicle Settings instrument panel menu. See INSTRUMENT PANEL MENU.
The following conditions apply, before auto access height operates:
The suspension height has to be set at the normal height setting.
The transfer box has to be engaged in high range. See HIGH AND LOW RANGE TRANSMISSION.
Select one of the following terrain response driving programs:
Automatic .
General .
Dynamic.
Grass/gravel/snow .
See TERRAIN RESPONSE OPERATION.
Auto access height initially lowers the suspension height up to 20 mm below the normal height setting, after any of the following events:
The vehicle is stationary and any of the occupied seat belts are unbuckled.
The ignition is switched off.
If a door is opened, after the initial suspension lowering, auto access lowers the suspension to 50 mm below the normal height setting.
NOTES
If a door is not subsequently opened and the vehicle’s speed exceeds 25 mph (40 km/h), the suspension height returns to the normal height setting.
Auto access height lowers the suspension height to 40mm below the normal height setting, if a door is opened before any of the following events:
An occupied seat belt is unbuckled.
The electronic air suspension system's down button can subsequently be pressed to lower the vehicle to the full access height setting. The full access height setting is 50 mm below the normal height setting.
Auto access height can be activated until 90 seconds after the vehicle becomes stationary.
Auto access height only operates once for each time the vehicle is stationary. If further operations are required while at the same location, use the instrument panel menus to disable and enable auto access again. Alternatively, drive the vehicle at a speed above 7 km/h (4 mph) for 3 seconds or at a speed of more than 15 km/h (9 mph).
NOTES
The once only operation also applies if the vehicle has been stationary for more than 90 seconds without activating auto access height.
Auto access height does not operate in the following conditions:
The suspension has entered into extended mode. See EXTENDED MODE.
The vehicle is parked on excessive inclines and declines, or on a very uneven surface.
If there are insufficient air reserves in the electronic air suspension system. In this event, the message centre displays a temporarily unavailable message, when a door is next opened.
Hope this helps
Wed Jun 01 2022 5:06pm |
