Home > Maintenance & Modifications > L494 Brake pipes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4384 |
Replaced loads of them too. Little frightening that the pipes on a 4 Yr old car has worse pipes than many, much older cars on the road |
Wed Dec 18 2019 10:02pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 581 |
Pic please of location on the vehicle |
Wed Dec 18 2019 11:41pm |
Best to take the wheel off if you can’t get it in the air,look in between the air bag & top suspension arm & that’s the pipe.It is bad DM,I couldn’t believe it when mine went in for service & the said my rear brake pipes were corroded,like I said before I’ve got 10-15 & even older cars coming in for MoT with brake pipes like new.
Thu Dec 19 2019 6:55am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
4yrs is pretty bad! They must be made of Chineseum alloy I mean - I had the same advisory on my car, but at 10 years old that doesn't surprise me particularly.. at 4 years old I'd be shocked. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Dec 19 2019 9:35am |
Hi Mate , Whats involved in fitting this pipe , my wifes offside burst last night |
Fri Oct 22 2021 6:45pm |
Easy enough to do if your mechanically minded,pipes goes from body in front of wheel fastens to top suspension arm & down to calliper.I bought my brake pipes from Advanced factors which are site sponsors for a lot less than LR dealers. Andy.
Fri Oct 22 2021 7:30pm |
Thanks, is it metal from the caliper then flexi and then metal again ? |
Fri Oct 22 2021 9:27pm |
Yes metal to flexi that’s the pipe.Itscthe metal bit that fastens to the arm that corrode.
Sat Oct 23 2021 2:36am |
Thanks again
Sat Oct 23 2021 5:22pm |
IronDuke50 Member Since: 04 Jan 2021 Location: North Yorkshire Posts: 9 |
Thanks for the post, excelent.
Sun Oct 31 2021 4:31pm |
Cover them in grease & they will last longer. Andy.
Sun Oct 31 2021 4:37pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1158 |
Only the rears, or should one replace all 4 corners? --
Sun Oct 31 2021 5:18pm |
Only the rears seem to corrode on the L494. Andy.
Sun Oct 31 2021 5:24pm |
Do you think it's because you lot have salt on the roads in winter? --
Mon Nov 01 2021 7:06am |
