Home > General > Chassis question
lkdgndg1
Chassis question
Hi on my 209 Range Rover sport 3.6 there are two big weights right at the back of the chassis on both sides and they are able to move, a bit like balance weights , does anyone know what they are for please .
Post #618503 Thu Oct 28 2021 11:07pm
They are harmonic mass dampers. They are used to tune the chassis' response to vibrations etc. They basically make the car a nicer place to inhabit. 2012 SDV6 - it's missing a couple of cylinders
Post #618504 Thu Oct 28 2021 11:13pm
They are Harmonic Damper weights supposed to help stop resonating noise/vibrations. They did move enough at one point on my car to knock on the bumper under sharp braking and made it sound like a knocking suspension, just wrapped a bit of foam rubber to them and cured that. There are a couple of similar lumps of metal bolted on to the chassis underneath the front door post area although the are fixed, assume they are for a similar purpose, same as the small metal blocks blocks bolted to the front calipers on the TDV8 Brembos.
Post #618505 Thu Oct 28 2021 11:14pm
lkdgndg1
Lovely thanks for the info I was wondering what they were there for now I know thanks.
Post #618528 Fri Oct 29 2021 8:26pm
