Home > Technical > 2 Concerns L320 - any help please
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Guys N Gals, I have a lovely Orkney Grey 2012 3.0 autobiography and have 1 issue I need to bottom out and 1 concern.
- Steering wheel wobble when braking, I have fitted new discs and pads but it still shows its ugly face when braking from about 40mph to a stop, Tyres are even. I think I have very slight play in the rear of the bottom arm bushes but they dont knock.
Could this be a Rack or the bottom arms? or wheel buckle?
- Coolant crossover pipe, I have read this is a weak spot but was superseded on later cars, is this something I should change or is my car late enough to be ok? if not is this a body off job?
Post #618456 Wed Oct 27 2021 4:40pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Wheel bearing?
Post #618461 Wed Oct 27 2021 7:16pm
Crraigymmmmm
Thanks. It's just passed the Mot. Are they harder to diagnose than other cars?
Post #618466 Wed Oct 27 2021 8:32pm
H2OOW
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
I fought with the same issue, it turned out to be a buckled wheel. 2012 SDV6 HSE Lux
Post #618484 Thu Oct 28 2021 9:52am
Crraigymmmmm
Thanks, will get them checked 1st then look at the wheel bearings.
Post #618486 Thu Oct 28 2021 10:52am
Crraigymmmmm
So I had the wheel balancing checked, swapped with the rears and the issue is the same..
I fitted Pagid discs a few months ago so im going to try genuine LR discs, There is slight play in rear bushes on bottom arms. bearing seems ok. was thinking to put poly bushes in the rear of bottom arms??
Happy to buy parts that are needed but dont want to go buying bits just to rule them out.
Post #618863 Mon Nov 08 2021 9:55am
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
I had similar and it was that the rear brake caliper had seized
so it was grabbing and that was the cause of the wobble
ended up with new discs, pads and parking brake pads.
Oh well all part of the fun! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #618893 Mon Nov 08 2021 3:16pm
Crraigymmmmm
Thats interesting. Ill check the heat on the rear brakes after a run later.
Post #618896 Mon Nov 08 2021 3:53pm
gogsy1956
I've had the same issue and mine was a sticky caliper well. Also had an out of shape wheel but that only caused a very slight steering wheel vibration at 50-60 mph. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #618897 Mon Nov 08 2021 4:04pm
Crraigymmmmm
Thanks, was yours a rear too? if I brake and get the wobble then let off the brake it stops immediately. and doesnt pull at all either direction. I can rule wheels out now. I know there is a slight bit of play in bottom arms so will inevitably change them or upgrade but dont feel they are involved in the wobble. I guess all that's left is the brakes (rear calipers to check) and im paranoid that the front discs are Pagids and not LR, also the wheel bearings to check but no abnormal noises from them.
Post #618898 Mon Nov 08 2021 4:18pm
gogsy1956
I think it might have been,, was found by accident if I recall,,,, had asked the handbrake to be cleaned out and adjusted correctly during a service and they found the sticky caliper when taking the discs off. I don't think I would worry about the lack of genuine brake discs,, other options available, I've used borg and beck brake parts many times,, good quality at a good price. 2010 RRS, TDV8
22" overfinch
Post #618899 Mon Nov 08 2021 4:51pm
Crraigymmmmm
Thanks Gogsy, it was more that I have read over and over since the last few days that only LR discs should be used due to non OE parts warping easy - so thought that could be it,
Post #618901 Mon Nov 08 2021 5:12pm
Crraigymmmmm
by way of an update, I have fitted new Polly bushes to the bottom arms up front and new LR bottom ball joints. most of the play has gone, the hydra bushed were well shot but passed the MOT??????
I still get a little bit of wobble like its trying to wobble when braking at about 50mph, noting at lower speeds. Ill put new track rods on as they are cheapish and need wheel alignments doing so will be a catch all,
the wheel bearings seem fine and I dont think its discs so once I have alignments done then it leaves only the wheels to check for straightness and balance.
Post #619431 Tue Nov 23 2021 10:25am
Scotty1980
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi Crraigymmmmm
Did you finally resolve the problem? I have a nasty wobble when I brake from 70 disappears below 50 or at least not noticeable from me. Also I have a vibration at speeds over 60, wheels balanced twice no difference but the vibration comes and goes. Irritating really.
Just wanted to know if the lower arms and track rod ends cured it.
Post #624470 Tue May 24 2022 1:43pm
Crraigymmmmm
Hi Scotty, After the bottom arms, I went for a 4 wheel alignment and changed the budget tyres that came with the wheels for Pirelli's - all sorted now! so I dont know if it was the tires or the balancing but all cured! however the bushes made the biggest difference, and the tyres made it perfect - if that makes sense.
I didnt change anything else mechanically in the end. However I did buy a set of Polly ARB bushes for all 4 corners so will get them on for fun!
Drives like a new car now!
Post #624473 Tue May 24 2022 2:15pm
