![]() | Home > Technical > EPB Squeal |
My car has close to 200,000km and the the only work done on the rear brakes has been one set of pads. At my last service I noted the rotors are getting a bit thin and the pads are down a bit so have these parts to go in soon. The hand brake has never been serviced and the shoes original.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
The suspension often drops a touch a short period after the engine is switched off and the doors closed. Could it be a suspension bush that's making the noise as the suspension shifts? 2012 SDV6 - it's missing a couple of cylinders
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Mine does that; stop, get out, lock the doors and the car 'relaxes' .. since my ARB bushes are, er, past their best, it creaks pretty loudly sometimes as it relaxes down. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thanks but is not suspension - it is the EPB squealing. 07MY RRS TDV6
