Home > Faults & Fixes > 2013 l320 steering Column Stopped Working
Jim D
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Hi all,
My electric steering column has stopped working all together. I have checked every single fuse in the boxes and even replaced the memory module under the drivers seat as, after looking at a wiring diagram it all seems to go through this but still no joy. I know that the full fats suffer from column issues but this doesn’t seem to be the case on sports? Everything else on that circuit works fine I.e the seats, Mirrors etc and when you try to move the column via the switch whilst moving positions it cuts the seat movement out like it’s supposed to. Has anyone got any ideas as I’m loosing the will with it and I can’t see it being both motors at fault (tilt and tele?) I attempted to carry out a seat calibration using a decent scanner but it failed and didn’t say why, is there anything within the seat that could fail and prohibit the steering wheel movement?
Any help or suggestions appreciated, despite reaching for hours I haven’t found anything to do with this issue on the sports.
Post #618065 Tue Oct 12 2021 7:04pm
