![]() | Home > General (L494) > Engine management light |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Just Google the fault code P0234, lots of hits, e.g;
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Thanks, turbo over boost, which doesn’t help a great deal. Anyway, was more bothered about the other questions I asked. Particularly does clearing a fault just mask it (like silencing a smoke alarm) or if the fault is ongoing, would the engine management light just come back in again. The fault code on the second reader said permanent. I think I’ve now worked it out that the light would light up if it was ongoing, and the “permanent” code will disappear once the car has run normally for a while (or relight the engine light if it runs abnormally again). Permanent just meaning you can’t clear it entirely, only the car can.
Scootrover Member Since: 27 Sep 2021 Location: Staffordshire Posts: 4 ![]() ![]() |
Is there any further update re this as I have had the exact same issue and code. RAC have cancelled it and the car was driving fine before and after the reset.
Yes - happened again yesterday. The throttle body was sticking. The light came on and shortly after, the DPF filled up. Then red lights, limited performance mode and a call to Land Rover assist - who replaced the throttle body and regenerated the DPF. RRS MY17 SDV6 AB
