Home > In Car Electronics > Steering wheel left side buttons inoperative. L494
djm1502
Apologies if this question has been listed here already but I can't see anything similar.
My RRS L494 2014 now doesn't work the left side steering wheel controls. Very occasionally one key press (eg vol up or down) belatedly brings up a different function (eg phone) but not reliably. Anyone had this and any ideas for a fix?
Post #617920 Tue Oct 05 2021 7:04pm
Farmer Chalk
Try disconnecting the battery for ten minutes and then reconnect…
You’ll find it should reset…
Post #617922 Tue Oct 05 2021 9:12pm
djm1502
Cheers. That won't have any other consequences will it?
Post #617990 Sat Oct 09 2021 5:06pm
Farmer Chalk
It shouldn’t do… we had the same issue … it was cured by the battery disconnect…
Worked perfectly afterwards… hoping it works for you!
Post #617995 Sat Oct 09 2021 8:32pm
djm1502
Cheers. I'll try it. Also saw a post on a North America RR website saying the left side buttons for this vehicle were part of a recall. If you google LTB00584NAS5 you can see it. Is there any way to see if this is also part of the RR UK service website? I think its maybe a known problem but I don't know how to make the case to the local RR main agent (since end of warranty its been serviced by a LR independent garage). Is there any UK website that has this detail you know of?
Post #618050 Tue Oct 12 2021 11:24am
