Home > Technical > ACE ARE YOU THERE!
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
ACE ARE YOU THERE!
Just bought an RR sport hse and one the faults showing is the ace hydraulic pump isn't working , apparently its had a new one fitted and so where is this pump please. The reservoir is full , but I get a feeling the suspension is soft and bounces a bit when manoeuvring slowly and braking . I also rolls slightly when cornering , would this be an indication a why it throws a fault.
Post #617858 Mon Oct 04 2021 1:05pm
what age car.
Please put it in your profile or signature
Post #617872 Mon Oct 04 2021 5:46pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi if a new pump was fitted was the system put through the bleeding process.I think there is a particular device that is used and a specific process.
Dynamic Response Bleed Bottle 204-591-01
Dynamic Response Control Box 204-591-02
https://www.rangerovers.net/threads/2010-2...de.330662/
Post #617874 Mon Oct 04 2021 5:54pm
Dynamic Response (ACE is an old name for a different system) effectively reduces the anti-roll function of the bars at low speed. This is to give low speed ride comfort (and also to help articulation off road).
Did you buy privately or from a garage / car dealer? If from a garage or dealer, take it back and get them to sort it out. They are legally required to do so - unless you bought it knowing it had the issue, of course. 2012 SDV6 - it's missing a couple of cylinders
Post #617882 Mon Oct 04 2021 9:46pm
alfapat
Apparently the system was bypassed , but I feel if I can understand something about it it would be beneficial, as it is quite soft, works better in Sport mode , handling that is , wishful thinking don't know .
So looking for info
Post #617890 Tue Oct 05 2021 7:59am
Disco_Mikey
What year, what engine, in what way has it been bypassed, is there a warning light on the dash?
Post #617898 Tue Oct 05 2021 11:45am
alfapat
57 Plate V8 Diesel, sorry I dont know enough about it , but I was told that a pipe was replaced and the system was disconnected. Seems like the seller doesn't want to help , I have mentioned it and that was his explanation . I reckon I got it at the price that suits. If maybe I can start at the beginning I will either delete altogether or sort.
No warning light. Code Ill post , thing it was not connected. Amongst other things , Think I have been too trusting !
Post #617919 Tue Oct 05 2021 6:40pm
Hmmm, there was a chap on the forum recently trying to sort out a TDV8 with a leaking system. Wanted to remove it and was generally told to forget it. Wasn't the same one, I wonder.
When the seller said a pipe was replaced, I wonder if he's just connected the pump back to itself and so disconnected the system from the pump. If so, the anti roll bars won't be doing anything if they've leaked out the fluid.
Sounds like you need to take it to a decent LR indie (not a main dealer or a general/4x4 garage). Someone who knows the system and can hopefully put it right for you.
The anti roll bars are expensive but you can get OEM ones for half the price that LR charge for them. If's got a leaking bar, it might just be a case of changing the bar and then sorting out whatever "disconnecting" the guy did. 2012 SDV6 - it's missing a couple of cylinders
Post #617936 Wed Oct 06 2021 12:39pm
alfapat
Soundslike a familiar story I was told. The Garage that the seller used was a specialist , but I think in order to cut costs , the seller by passed the cost and sold it as it was . I am going to get more information on this one.
Need a workshop manual!
Post #617975 Fri Oct 08 2021 4:53pm
jimbg
Member NAKS has a link https://www.mediafire.com/folder/bmioajx5v76k7/RR 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #617976 Fri Oct 08 2021 5:38pm
alfapat
I downloaded the file , and adobe , mainly to use a search facility to avoid endless scrolling . Its Still not helping , so can anyone give me pointers , not too savvy on files.
Post #617992 Sat Oct 09 2021 6:17pm
jimbg
PM NAKS? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #617994 Sat Oct 09 2021 8:28pm
alfapat
Is there a guide somewhere that I can check out the Dynamic response system to see what's needed to restore it and get it working gain , there are no leaks but I just get C1119-09(AF) Hydraulic Pressure- General failure information-component failure .Where do I start and is there a pathway . Perhaps the whole thing needs to go to manual I not sure.
Post #618161 Sun Oct 17 2021 7:39pm
Disco_Mikey
This is painful to follow...
Either:
Have a look through the manual, locate the components, and work from there
Or,
Take it to a local specialist, and let them assess the car...
Post #618164 Sun Oct 17 2021 8:05pm
alfapat
Yeah , sorry its painfully for me as well , not knowing the system in car from the start , I've been sold a pup , not far from your area as well , mildly passed off! MY FAULT , JUST TRYING TO RECTIFY. Sorry for the shout !!
There were no faults on the dash , just in case you think they were there to see when I bought , the car , I don't think the seller expected me to see the faults on a diagnostic which I have. Amongst other things , parking sensors, aircon , aux heater, oh and fuel flow sensor where the engine went to fault overtaking and losing power! Sorry about rant.
Post #618167 Sun Oct 17 2021 10:09pm
