![]() | Home > Technical > Front 12v socket and DRL not working |
If this problem has just manifested itself since the manifold repair I would guess that a wiring harness has been damaged somewhere. Have a good look at any accessible wiring in the engine bay making sure nothing has been nipped or jammed against a hot surface. 2010 RRS, TDV8
may want to follow the DRL wiring, to see where that goes.
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 ![]() ![]() ![]() |
Yeah I’m going to look in morn see if I can see anything but I’m defo leaning towards the two problems been from same cause and I think garage has caught a loom somewhere when doing the manifold as before both worked perfectly
