Home > Detailing & Car Cleaning > Black parts... advice needed
Baker3570
hi all...
I'm after some advice on the black trim that goes around the A / B / D Pillar etc... mines faded what do people use on this to bring it back to life or do they need to be painted?
Also for the scuttle panel at the bottom of the windscreen what do people use on this?
any info is appreciated
Post #617657 Fri Sep 24 2021 9:05am
Oldandconfused
For the pullar trim I use quick detailer because mine isn't faded. If yours is faded it might benefit from a MOP to take the fading off, then keep on top of it. The scuttle is typically a poor choice of plastic. It goes grey and anything you put on it is only going to be temporary. I used autoglym bumper/rubber treatment, some use Gtechic G4 i think. There is a thread either on here or the D3 site where someone took it off and painted it, which I imagine should last.
Post #617658 Fri Sep 24 2021 9:29am
Stevepd
My black trim is still black, but my skuttle panel was greyer than a grey thing. DrRob put me onto this Gtech G4 stuff that O&C mentions above. This is magical stuff, a bit pricey if you see the size of the bottle. You don’t need much and a small bit goes along way. 100% recommend it. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #617660 Fri Sep 24 2021 10:50am
If you do a search on here, someone actually recommended peanut butter for the black scuttle panel. I would guess it's the oil in it that makes the plastic look black again. No idea how good it is at keeping the plastic black, however. 2012 SDV6 - it's missing a couple of cylinders
Post #617664 Fri Sep 24 2021 11:29am
Scrumpy
Crunchy or smooth? Laughing 2016 RRS SVR Estoril Blue
Post #617665 Fri Sep 24 2021 12:17pm
Have a read and see for yourself:
https://www.rrsport.co.uk/forum/topic48059...nut+butter
https://www.rrsport.co.uk/forum/topic23704...nut+butter
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #617666 Fri Sep 24 2021 12:29pm
knwatkins
I sprayed mine which resulted in zero maintenance thereafter...
https://www.rrsport.co.uk/forum/topic53714.html Kev
Post #617668 Fri Sep 24 2021 3:41pm
Oldandconfused
That's the thread I meant. Good job.
Having had rats eat half the fuel lines in the wife's Ckrsa dog van, I'm reluctant to put anything edible anywhere near the engine.
Post #617675 Sat Sep 25 2021 6:50am
knwatkins
Thanks. If anyone decides to do this, whilst you have the scuttle off, it's also worth making a little water deflector for the air intake to avoid soggy carpets in the future...
https://www.rrsport.co.uk/forum/topic49602.html Kev
Post #617676 Sat Sep 25 2021 7:49am
Pitcher
Meguiars ultimate black, it is a white cream, although didn't streak, it left run marks on the paint underneath after rain, wiped away quite easily though.
It didn't work very well on the skuttle panel, but that seems more rubbery than plastic?
I do have some Autobrite direct stuff to try next, here it is the Meguiars on my 2011 plate.
Post #622955 Sat Mar 19 2022 6:32pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
#2 for Maguiars Ultimate black, works a treat on all black pillar trims and grey lower trims and lasts well. Wouldn’t work on the scuttle trim so I removed and painted mine.
 Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #622961 Sun Mar 20 2022 1:02pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi I had the same issue with the scuttle panel and used a product called Ceratrim . It worked wonders on it and brought a colour back to it.Cant rate this stuff high enough. Thumbs Up
Post #622963 Sun Mar 20 2022 3:48pm
Oldandconfused
How durable is the Ceratrim?
The Autoglym stuff is gone in a few weeks.
Post #622964 Sun Mar 20 2022 4:40pm
Iomegas
Hi it’s great I just go over it every 3 months approx Thumbs Up
Post #622965 Sun Mar 20 2022 4:50pm
Lindab
Gtechniq C4 Permanent Trim Restorer
Once a year, small bottle, but you use it sparingly Thumbs Up Thumbs Up Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #622973 Sun Mar 20 2022 10:03pm
