Home > In Car Electronics > Resting Heart Rate |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Are you checking soon after you turn the car off? I think it takes about 10 minutes for all the systems to shut down and go into standby.
Thu Sep 23 2021 11:11am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Good point. Checked just now and its 12.03 and flickering between "Discharged" and "Fully Discharged"
Thu Sep 23 2021 12:07pm |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 247 |
Based on my boat's batteries - at rest they should rest at around 12.8v MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Thu Sep 23 2021 12:19pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
12.03v is too low,, it's bordering on letting you down 12.6V is a fully charged battery. I have a monitor on mine, the battery is quite new and it never drops below 12.4 ( unless cranking of course). I even checked it against a good quality multimeter just to make sure it was a true readingj. 2010 RRS, TDV8
Thu Sep 23 2021 12:28pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1831 |
Posted this many times before!
Thu Sep 23 2021 2:17pm |
OK, so its fubar'd then |
Thu Sep 23 2021 9:26pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
How long do you run the engine when it is running? If you're doing shorter journeys, the battery won't get charged up.
Thu Sep 23 2021 11:14pm |
I think its stuffed as I had I charged it fully on Monday and on Tuesday I did 2 1/2 hour runs and on Thursday its as it was in this thread. |
Fri Sep 24 2021 11:20am |
The trouble with batteries is that they will start now on a reasonable weather day, but come winter that is when is will let you down.
Fri Sep 24 2021 11:24am |
Ah, that does sound like it's FUBAR'd. What's the alternator's output like? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Sep 24 2021 11:27am |
11.97 today (24 hours+ later)
Fri Sep 24 2021 6:25pm |
