![]() | Home > General > 07 model year sat nav on the move [ question ] |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
The latest 07 sports will get sat nav on the move - ie enter postcodes whilst driving.... does anyone know if this will be available as on upgrade/software fix for our older sports |
Don't see why not, if LR can be bothered to produce it. |
EXPIREDDATA Member Since: 28 Aug 2006 Location: West Sussex Posts: 221 ![]() ![]() ![]() |
This may be a silly question - but how does the old sat nav know that you are moving ? -
The ECU knows! 2005 Zambezi TDV6 - Gone but not forgotten
You'd hope so - but wouldnt it be simple to remove the connection between the ECU and the Satnav ? RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system BMW GT |
Dont think you'll find its a simple connection????? Itls all software related/talk between all systems ecu/satnav/ignition/NASSA etc etc all connected via a system called "most" |
I would think this would confuse the system. The ecu knows how fast you're traveling linked in with the sat nav etc.etc. = position on map. 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
Or am I talking b |
broomsticks |
The ECU wouldnt get any speed from the satnav. After all - GPS speed isnt accurate and is an average speed between two points. I'm sure there must be an easy way to override this functionality... RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system BMW GT |
The ECU gives it to the sat nav system. 2005 Zambezi TDV6 - Gone but not forgotten
Why would it - The satnav can work out the speed using the GPS data. It wouldnt be able to do anything with the data anyway. RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system BMW GT |
Does Hybrid TV switch off when moving as well ? RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244 ![]() ![]() ![]() |
Hi
