![]() | Home > In Car Electronics > DAB Issue and MOST |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 ![]() ![]() ![]() |
Think I've found the issue, the Fibre connector to the Amp is damaged, you can wiggle it and the red light goes on and off, can anyone recommend where I can get a replacement cable?
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
from a dealer it would be expensive so try ebay or a breakers yard... |
clarker63 Member Since: 10 Feb 2023 Location: Devon Posts: 16 ![]() ![]() ![]() |
I have a similar issue, can you tell me where you found this cable? Thanks |
